Resume Word Report
I am currently having problems opening a Microsoft Word document in LabView. I currently have "lab reports" on my computer that were created from a different LV program. I want to open these Word documents in Labview and "resume" these documents by appending a new report to them.  Both the saved reports and new reports will have multiple pages of tables/graphs on each page.
I haven't started programming the rest of the project, as I am currently stuck on how to open/append a microsoft word document in Labview to alter. I tried using the Microsoft Insert Object vi, but this method inserts 1 (and only 1) page as an object and appends it to another report.
Any help would be appreciated!
Message 1 of 9
(4,069 Views)
Are you using Report Generation Toolkit or ActiveX with your Word doc?
Message 2 of 9
(4,049 Views)
ActiveX
Message 3 of 9
(4,030 Views)
Do you want to add text to the existing report?
If so append object is not the way to proceed.
You can use ActiveX to include your text at a given location within Word and at the same time format the text.
There should be an example floating somewhere in the forum.
R
Message 4 of 9
(4,027 Views)
The report has text, images, and tables.  And you are correct, the Insert Object vi inserts the first page as an object.  Currently I'm trying to figure out if I can get all the contents of the document and append it to another document (also which has multiple pages).
Message 5 of 9
(4,023 Views)
It's been a while since I've done this.
From what I can remember, you may need to add / append your text, image(s) and table(s) in three different steps as they are not a common object.
Otherwise it will add everything as a single image object which is not text for the text portion..  You already know that since you're posting the question. 😉
Message 6 of 9
(4,008 Views)
Haha, indeed.  I was hoping you wouldn't say append them all seperately.  I suppose if this is the final method, I have no choice.  I'm still toying with it with no success (I'll post something when I run into a step towards the right direction). Any other suggestions?
Message 7 of 9
(4,004 Views)
I don't think there is any other way...
Message 8 of 9
(3,989 Views)
This has been cross-posted on LAVA.
Message 9 of 9
(3,980 Views)
