Resize an array in the front panel
I decided to edit a project to make the window a little bit smaller so It would perfectly fit a smaller screen, but after I tried to decrease the size of the main tab, some of the arrays I had in the rest of the tabs of the front panel changed its size and I cant turn them back to normal.
In particular, those highlighted in red.
The small square with the arrow pointing down used to fit next to the blank space, but now it moved down.
I've tried to resize it manually but it only changes the dimension of the array, not its size in the front panel.
Can anyone help me fit that arrow back to where it was?
(4,656 Views)
Check scale option.
And then try customize your control.
(4,634 Views)
Additionally, have you selected under File -> VI Properties -> Windows Appearance to Fit to Screen?
(4,585 Views)
