Resetting While Loop Iterations after Case Structure
I want to reset the iteration count (i from while loop) after the case structure goes from false to true. How would I do this?
(1,802 Views)
Store your own count in a shift register.
(1,796 Views)
Hi Sam,
You cannot change the value that loop iterator outputs…
But: you can create your own counter using a shift register!
(1,793 Views)
Please attach your VI instead of a series of images.
  • You have not followed any of the earlier advice.
  • Your use of value signaling properties is completely pointless because you don't even have an event structure. It also executes in parallel of writing to the table terminal and whatever happens last wins. No way to tell. You can significantly simplify all this.
  • You don't even need to maintain a count, just measure the "size +1" of the number of rows in the array. Right?
(1,776 Views)
