Resetting IMAQ
I have a few programs that rely on the producer/consumer loops for image acquisition. The programs work fine with the same basic structure, except for one detail. After data capture is complete and I run the application again, the no data streams into the buffer. I have to begin acquisition again, stop it and then re run the program. Then everything is fine. I'm not sure what I'm missing as I believed that I was resetting all applicable variable to default at every startup. Any information would be greatly appreciated.Capture.PNG
(2,909 Views)
" the no data streams into the buffer"
What does that mean? Are you getting any errors?
(2,899 Views)
I *just* figured it out. There was a 'true' constant in the producer loop for some reason (bottom left corner of top loop). This froze the loop on restart after acquisition.
(2,896 Views)
That's odd. It seemed to work at first, and now it's back to doing the same action. Will look more closely.
(2,891 Views)
