Resettable counter?
I am attempting to use an increment and feedback loop to tell me the number of iterations a case structer has under gone (I only want to save a desired number of files). Attached is a basic example of what I'm doing...
It works well the first tiem though, but is there a way to reset this counter when I turn the switch off and back on again?
Is there a better way to incorporate a counter just for the case structure?
Thank you,
Brent
(3,396 Views)
Try my attached example.  It is better to use the shift register than the feedback loop, it follows the dataflow programming style.  I think it is what you were looking for but be sure to let me know if I misinterpreted your request.
Cheers!
(3,390 Views)
Perfect! thank you so much.
(3,376 Views)
