Reset revision history for all VIs in an llb
Is there a way to clear the revision history for multiple VIs at once, specifically all in a particular .llb.  I know how to clear each one individually, but what a pain.  I hoped if I took the top vi in llb and saved as, and created new hierachy, all VIs would reset...no go.
I would really like to disable the rev history feature.  I know you can chose not to display the history, but I cannot figure how to disable the rev history feature itself.  Meaning, if I change a vi 10 times and someone else turns on the view feature, it will always show 0, or 1, not 10.  I want to release new software with all set at 1st rev, but I find no other way to do this except go and reset the history for each individual VI---UGH!
Thanks in advance!
Shannon F
(3,855 Views)
Accepted by topic author sfleming
You can reset a VIs rev history using VI Server to load the vi and a method to reset. See attached (LV 8.6)
(3,841 Views)
Thanks for the info and sorry for the late reply.  For some reason I didn't get an email from NI (as usual) to inform me that somone (you) replied to my question.
It looks like I need to put this code into all of my VIs to reset each one individually, which is the route I might take.  I have about 30 VIs in the llb, so unfortunately I have to add 30 times at this point.  I wish there was a way to reset all automatically using a tool in labview.  Obviously there is on option from the drop downs (or cntrl y) to reset each VI individually.  Wonder why they don't have a global reset or why creating a new hierarchy (save as option doesn't work).  I may just have to bite the bullet and add what you sent to each of the 30 VIs.
However, this is great information for my next project, I will just add it to new VIs from the start!
Thanks for your time and input!!!!
Shannon F
(3,758 Views)
You've already asked this question before, and I've already provided an answer.
Please do not create multiple threads asking the same question - this is annoying.
(3,744 Views)
Sorry, thought the 1st one didn't get posted...forgot to subscribe and couldn't relocate.
Shannon F
(3,736 Views)
Exactly what I needed!!!!
tks
Shannon F
(3,735 Views)
