Reset clock count/encoder counts
Is there a way to programatically reset the clock count using labview? I am using an encoder and an e series DAQ board. When I am counting with the encoder, I come to a point where I would like to reset it to zero. I see that the examples all show that the count is reset after the loop is complete, but I would like to reset it during the loop to use it as a positioning tool. Reset to zero then start counting again from that point. Is this possible? Thanks.
Using Labview 6.1 and MIO16E DAQ Board.
(4,039 Views)
Use the "Counter Control.vi" (Data Acquesition-> Counter->Advanced Counter). With the control code 1 you can resets the counter. Alternatively you may use the VI with control codes 4 and 2 which disarms and arms the counter again ("If you follow a disarm with another arm, then the acquisition restarts from the beginning"). That should do.
(4,039 Views)
(3,763 Views)
