Rescripting Actor Messages in LabVIEW 2023 Q3
I have confirmed that these files are identical in a seperate 2023 Q1 installation I have on another PC, however, rescripting works just fine in 2023 Q1.
Message 11 of 17
(1,224 Views)
Have you submitted a support ticket or bug?
If you open any of these files, do they open broken in 2023Q3? (I can keep exploring ideas in lieu of NI helping but of course it's exploratory in nature)
C:\Program Files\National Instruments\LabVIEW 2023\resource\Framework\Providers\MessageRescripter\Item_Init.vi
C:\Program Files\National Instruments\LabVIEW 2023\resource\Framework\Providers\MessageRescripter\Item_Interface.vi
C:\Program Files\National Instruments\LabVIEW 2023\resource\Framework\Providers\MessageRescripter\Item_OnCommand.vi
C:\Program Files\National Instruments\LabVIEW 2023\resource\Framework\Providers\MessageRescripter\Item_OnPopupMenu.vi
~ Helping pave the path to long-term living and thriving in space. ~
Message 12 of 17
(1,205 Views)
Yes, NI confirms that this is a bug (not a feature) of 2023 Q3. They are determining whether they will patch or wait until next release (I really hope the former).
I will check those VIs and get back to you.
Message 13 of 17
(1,200 Views)
When I open the items you listed, the are fine in 2023 Q3.
Message 14 of 17
(1,173 Views)
LabVIEW R&D is currently investigating this issue (I don't have a Bug number associated with the issue yet). However, I do have a workaround. You can replace the following VI with the one attached to this reply (LabVIEW 2023 Q3 only):
[LabVIEW 2023]\resource\Framework\Providers\MessageRescripter\Support\Is Message.vi
Make sure to backup the existing file first, just in case. After replacing the file, restart LabVIEW and you should see the rescripting right-click menu item present and functional again.
Message 15 of 17
(1,155 Views)
Thanks for your sharing, its worked.
Message 16 of 17
(1,084 Views)
This bug is fixed in LabVIEW 2023 Q3 Patch 1, now available for download in NI Package Manager.
Message 17 of 17
(981 Views)
