Rescaling axis problem
I am not being able to rescale X-Axis as my data acquisition is progressing. It is always stuck in some constant value. How can I solve it?
(3,353 Views)
If you are using waveform graph and have wired the waveform to it then remove the check mark from "Ignore timestamp" in the right click menu for graphs.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(3,336 Views)
Hi BRoy,
I'm not completely sure I understand what behavior you are seeing.  Are you trying to type in a value and it keeps reverting back to the same constant value?  Do you have AutoScale X turned on?
Justin Parker
Product Support Engineer
(3,310 Views)
Hi guys,
Thanks a lot for the input. I did try to 'autoscale' and to remove' timestamp' but these didn't help. Ultimately our regional NI field manager Dave Bonal helped me out. He change the sample no to 1, and few simple steps, like increasing graph data point etc.
Thanks Dave
BR
(3,299 Views)
