Resample data at a higher rate
I need to resample data at higher rate. I was able to use matlab interp function to interpolate my data. Bellow is the description of the matlab function. Is there a function or vi like this in labview.  My data is in the form of a .dat file. I tryed using the interpolate 1D array function in labview but this does not work.
INTERP Resample data at a higher rate using lowpass interpolation.
    Y = INTERP(X,R) resamples the sequence in vector X at R times
    the original sample rate.  The resulting resampled vector Y is
    R times longer, LENGTH(Y) = R*LENGTH(X).
Mark Mutton
Electrical Engineer
(2,816 Views)
Hello
In tools palette> analyze > waveform conditioning  you have vis for resample, (continous and single shot) with different choices of method. They do the job pretty well.
Hope it helps
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,805 Views)
