Requirements Gateway - unit test and getting started
Hello All,
I am not sure this is the right place but ... I am new to using Requirements Gateway. I have been looking at Requirements Gateway to manage requirements coverage for a medium sized project. I would like to use a word document as the source of requirements, connected(?) to a dedicated Labview project containing the vis and their unit test. Is there a way the unit test can be run from Req Gateway?
During a demo of Req Gateway a few years back I spotted the results were placed into (from memory ) an excel spread sheet and this provided a very simplistic view in terms of completeness. The format was something like:
[REQ_123456] [ Req Description] [ vi name] [ test coverage %] [ Pass/Fail]
[REQ_654321] [ Req Description] [ vi name] [ test coverage %] [ Pass/Fail]
and so on.
The test report examples I have seen so far dont seem to provide this view.
I havent been able to find anything similar, are there any examples, toolkits I should be looking at?
Thanks in Advance, Chris
(3,163 Views)
Hi CB,
I would recommend consulting some of the help resources available online. The two links below are html documents which should provide all the information needed to use Requirements Gateway proficiently.
https://www.ni.com/docs/en-US/bundle/371714f/page/download.html
Since you mentioned that you want to use the program in conjuntion with LabVIEW, I'm also going to link you to a white paper and a tutorial, both of which include further instructions on how to do this.
https://www.ni.com/en/shop/software-portfolio/ni-requirements-gateway-for-test--measurement--and-con...
http://www.ni.com/tutorial/8420/en/
I hope these resources are able to help you get started with Requirements Manager, please let me know if you need more assistance.
Jake A
National Instruments UK and Ireland
(3,085 Views)
