Requirements Gateway: Visio - COM error
Dear Developers!
I have a problem using Visio files in Requirements Gateway 1.1: when I open the example project ('Visio Example.rqtf) this info is shown:
Error: COM error (Class not registered)
Error: Conversion problem (file ...\Visio Example.vsd)
The operation system is Windiws Server Standard SP1. There is no full version Visio installed only Microsoft Office Visio Viewer 2007. Could this be the problem, or should I change some configuration of the Requirements Gatewaw?
Knáb László
(2,434 Views)
You can perform traceability analysis on Visio documents by capturing
traceability information from the custom properties in Visio 2003 or shape
data in Visio 2007 or by creating references in the Graphical View in
Requirements Gateway.
(Excerp from "Coupling Microsoft Visio with NI Requirements Gateway")
Hm, i would say your guess is quite promissing: you will need i full version of Visio in order to get it to work since ther is nothing said about Visio Viewer.
Maybe you can get some kind of evaluation version for Visio in order to test this.
thanks,
Norbert
Norbert
Expert: Geometry
(2,424 Views)
