Required Square waveform generation in DAQMx starting from 1 v AND ending again to 1 V.
Hi Sneha...,
can you explain a bit more please? You can use the "Square Waveform" function or you build your waveform with the "build waveform" function.
Mike
(2,791 Views)
hi,
Let me give the brief description.I can use Square Waveform.vi and i am using the same to generate square wave.In this Subvi if i give frequency has 1 Hz, Amplitude has 1 V signal starts from +1V and ends up to -1 V but i require signal starting from 1 V and ending up to 0 V back as shown in image so i replace the last data obtained in an array from Square waveform.vi from -1 to 0 and i was able to generate the required format but if i feed the same generated data to CARD PCi 4461 Using NI DAQMx programming and view the output generated from Card through Oscilloscope i am not getting required Square waveform.Instead data ending to 0 it is ending shooting up to 1 V .There is inconsistency of data generated in output channel as per observed in Oscilloscope.I am also using AO DAQMX channel property node -IDle Output behaviour property to maintain existing value.
(2,786 Views)
Hi Sneha...,
can you show your vi where your write your generated data to the hardware?
Mike
(2,783 Views)
(2,764 Views)
