I can't figure out what's going here. It' seems to be some sort of memory allocation issue.
The
first time I run the "Smaller Version.vi" attached VI, the Time Stamp converts correctly to
a LabVIEW Time Stamp. Subsequent runs without closing the VI result in
the Match Pattern function not finding the colon and not converting the
time correctly.
If you run it with Highlight Execution on, you'll
see the Match Pattern function does not find the first colon and
outputs a -1 on the Offset Past Match terminal which stops the loop, as
it should after it finds the last colon on a good run.
If I close and reopen the VI, it runs correctly the first time, but again incorrectly after that.
We've managed to find two things that will make it run correctly without closing.
If
you make either of the array index controls larger, as in able to
display a larger number (stretch it to the left) it will again convert
correctly once.
What seems to fix it for good is to either
remove the "Request Deallocation" function or change it's flag to a
False. So this seems to be the root cause of the problem.
The "Samllest Version.vi" attachment shows the same problem but without
any arrays, so the problem seems to be with the Request Deallocation
function. And in case you're wondering why I'm using this function, the
full version of this VI has a lot more going on and usually reads in a
data file with several hundred thousand data points for processing and
I wanted to clean the memory after this was done.
We've
verified this on two WinXP Pro SP2 PCs running the downloaded version
of 8 activated as the Pro version. I saved it back to 7.1 and it works
fine there.
I've already talked to NI support about this and will post the feedback.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
