Report generation
Hello all,
I have a problem in report generation subvi - it shows the data only from the first page of the tab (Baseline).
In order to check it the Main file should be executed. Then, one press on run button and the report is generated.
Thank you in advance,
Hanan
(2,570 Views)
Thats becasue when you are pressing generate report from the front panel inside case structure only baseline graphs arew there.
Inside case structure use one more case structure and input to this case structure is tab. Then try. It should work.
Let me know the result
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,553 Views)
