Report generation problem in 6.1
Attached file worked fine under LabView 6i but not in 6.1. The problem seems to be with the Set Report Font VI which doesn't like the words "Arial". Anyone else had this problem or is it something peculiar to my PC?
(2,472 Views)
Here are the two steps I took to get the VI to work on my machine:
1) Recompiled the code by ctrl-shift-clicking on the run arrow.
2) Changed the string in the 3rd frame of the sequence that goes into the Append Front Panel Image to Report from I Graph plot.vi to I_Graph_plot.vi.
After making the changes I did a File->Save All.
(2,472 Views)
