Report Generation
How can I update an open Excel report with a date in this format 10/04/2012.  When I try it, the date overwrites the previous date instead of going down to the next row.
Message 1 of 12
(5,831 Views)
Looks like you have append new line set to false.  Set to True.
Mark Ramsdale
Message 2 of 12
(5,816 Views)
I tried that I had the same result.
Message 3 of 12
(5,814 Views)
Here is a snippet that appends lines to a report.
The PNG you provided doesn't explain how the report reference is generated and it only shows one "run" of data.  This snippit is generic loop.   If you can provide more detail this can be looked at.
mark
Mark Ramsdale
Message 4 of 12
(5,809 Views)
Will this work in Excel too?
Brad
Message 5 of 12
(5,804 Views)
Of course not, that would be to simple 🙂
let me see why it is over writing.  Smiley Happy
Mark Ramsdale
Message 6 of 12
(5,800 Views)
Here ya go.  I often have to build wrappers around the report VI's in order to mess with formatting and stuff.  In this case the Excel position.
Interestingly, the append no longer seems to matter with excel.
Mark Ramsdale
Message 7 of 12
(5,797 Views)
Mark,
Pretty sure this changed when they rewrote the toolkit to use classes.
Message 8 of 12
(5,787 Views)
I was wondering how to interact with the MS Office Parameters!
Thanks!
Message 9 of 12
(5,786 Views)
Accepted by topic author Brad_Henry
Works great!
Thanks for your help!
Brad
Message 10 of 12
(5,771 Views)
