Report Generation Toolkit: How to programmatically insert same values across a MS Words template
  I currently have written an application that reads information from an Excel/CSV file and key into the Words document.
I did this by introducing a specific bookmark inside the Word document and use the Append Report Text.vi to insert the bookmark.
Now, there are some values where it requires the same bookmark to appear in multiple places. Ie. The same value should be replicated
in many places. I tried to insert cross-references in the template, but whenever the Append Report Text is performed, it overwrites the bookmark.
Hence the cross reference cannot find the bookmarks again.
Another issue is the font size of the replacement. It seems that it keeps on replacing it at Font 10.
Whenever the above VI is called. Is there a way to retain the same bookmark font as per what was saved as the template?
Thanks & Best Regards,
Kah Wai
(2,955 Views)
I think I manage to resolve this using the VI created by Henrik Volkers
http://forums.ni.com/t5/LabVIEW/How-to-edit-text-in-MS-Word-HEADER-using-bookmarks/m-p/1477060#
Sorry for the post
(2,948 Views)
