Report Generation Toolkit Error
I  have an application that generates multiple excel spreadsheets each containing a table and four graphs.  This has been working fine for three months but I am now getting error when generating the reports.  The source of the error is in the Excel_create_workbook as indicated on the attached picture.  I am passing in a template name for my excel reports.  The error code (-2147352571) states a type mismatch.  The file path to my template is a constant so I can't see how sometimes I get a type mismatch and other times I don't.
Any help on this would be greatly appreciated.
Thank you,
AJL
(2,980 Views)
Not sure this will help but worth a try. Since you have a coercion dot on your template input, wire the path control through a To Variant function (from activex pallete) to that input.
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,959 Views)
Thanks for the reply, however, this VI is part of the Report Generation Toolkit so I don't want to have to modified NI's code if possible.  I did try your suggestion without saving the VI and I still got the same error.
Any other ideas?
BTW - I encountered this problem first in an executable but have since seen the error in the development code.
Does anyone know if there is a limit to how many times you can create an excel document from LabVIEW?  I wouldn't think so but the error seems to happen if I try to create several (more then five usually) documents at a time.
Thanks in advance
AJL
(2,940 Views)
