Report Generation Toolkit Error Quick Question
     I created the most awesome LabVIEW report ever at my desk using a trial version of the RGT and Office 2003.  I took this to my production machine and ")@#(&%(*#^%()^!!!"  The production machine has office 2007 and a fully licensed version of the RGT.  Both machines have LabVIEW 8.6.0.  I've read all the stuff about these errors and something about classes and dll's and whatnot's.  So my quick question, is:  Instead of matching the versions of Microsoft Office as recommended, can I just rewrite from scratch the VI that creates this world's most awesome LabVIEW report on the production machine to create the same effect?
(3,283 Views)
Hi
Quick Answer: Probably
Slower answer: Microsoft changed a lot of things behind the scenes in Office 2007, but the Report Generation toolkit version 1.1.3 supports Office 2007 so you should be good to go. Depends on what functions are included in your VI. Liek the read me says "Several default settings in Microsoft Office 2007 differ slightly from previous versions. Reports you generate using Office 2007 might look different than reports you generate from other versions of Office because font sizes, cell sizes, and so on, differ."
Best Regards
David
NISW
(3,254 Views)
Accepted by topic author asb9ab
I'm not sure what the issue was, but I relinked all the RGT subVI's on my actual machine and it seemed to work fine.  Thanks for the answer.
(3,218 Views)
