Report Generation Help
I want to create a (LabVIEW6.1/2000/&XP) test report with  following features:
1  It must include company logo at the top (I can do it below the header. But I want it as a part of header or above it, but not below the header)
2  Report must include tables+ graphs in following format:
 Table to the left – Graph in the Center – table to right
3   Fonts type / size/ color of table as a ‘single unit’ should be selectable.
5   If possible Fonts type / size/ color of individual table item should be selectable.
6  I do not wish to print the report. I want to save it on the hard disk.
7  I realize that program may create a set of GIFs for charts. I want to know the list of all files program creates. Also I want to store all related (graphics, txt , HTML) files of a report, under one location.
8  I want to save the space when I create a report.
Can someone please throw light on best ways to do 1 thru 8 ?
Some clear examples of doing the above will be appreciated.
Sandeep
(3,284 Views)
You have not made clear whether the report should be in Word format or Excel format !
In either case suggest you look at the report generation kit that NI provides.
.The Report Generation for Microsoft office provides examples to get you started in either mode.
Contact your local NI rep for further details or check NI web site.
chow
 xseadog
(3,273 Views)
report can be an 'html' format or 'word' document format, even 'pdf'
will do.
it needs to combine tables, charts.
(3,267 Views)
If you have the report generation kit installed
then just search examples in labview help.
Attached vi is from example ( NB all sub vi are in NI labview .llb)
IF RGK is not installed then can't run, vi terminal will default to either Report or HTML  you will not have opportunity to
select word or excel format.
Chow
xseadog
(3,260 Views)
