Report Generation -- Excel works, Word doesn't (Error -41106) after O365 pushed out
I have searched the last day and a half and haven't found a solution.  I apologize in advance if I overlooked the answer somewhere...   Throughout I am using the "Create Report VI" to open Excel and Word files.
Before IT pushed out O365, Excel and Word worked fine with Report Generation.  After that, I got Error -41106 for both Excel and Word.
Following a solution found on this Board, I went in and modified the Registry for excel by deleting the last Excel registry entry.  Excel opens now in LV with no error.
Ignorance being what it is --  I am not an IT or Windows guru -- I located the Word entry in the registry and duplicated what I did for excel.  I still get Error -41106 for Word.  Word still started normally so I didn't break anything that is noticeable.
For what it is worth, there is a difference in the Word vs. Excel registry as Excel references a .exe and Word references a .olb file.
As I said, I am not an IT or Windows person (I'm a hardware person who spends most days sniffing solder) so this may be a simple thing to fix but I have exhausted the LV discussion board and Google searches in finding a solution that works.
Thanks in advance for any advice,
Ben
(3,551 Views)
Good to hear that you were able to get Excel working. If the registry method did not work. I would recommend uninstalling and reinstalling Word as this is actually recommended to do before you start messing around with the registry.
(3,488 Views)
Hi Ben, and Everyone,
This was the most recent and relevant post I found on this error and I wanted to share this solution as it worked in my case.  I got a new Windows 10 PC from IT with O365 (32 bit) already installed, downloaded LV2019 (also 32bit).  Immediately got Error -41106 with word and excel, the registry looked correct and I didn't want to go through IT to reinstall word.  I opened "settings - apps and features" in Windows, found O365 and hit "Modify", followed the prompts to "fix" the program and, to my surprise, this solved the issue.  I would recommend trying this to anyone who gets this error!
(3,288 Views)
