Replacing missing references
I'm fighting with a probably very common problem, in an old project we were using an .lvlib and and an .llb libraries.
The original files are missing but we got newer version of the same libs and included VIs have the same 'interface'.
If I try to use "Replace with" function I can only point to a VI (that will probably work for .lvlib related VIs) but VIs package within .llb cannot be referenced in this way...
Is it possiible to replace such references without having to check for each caller and rewire the whole thing?
Best regards.
 mike
Message 1 of 1
(57 Views)
