Replacing elements
@Nghtcrwlr wrote:
Ok.. sorry for the complications.  Array A is actually the replacement elements. If Array A has three elements, then last three elements of the Input Array have to be replaced by these. If 4, then last 4 lements. and so on...
So why are you autoindexing on array A. Simply calculate the size difference and find the index where the replacement should start. No loops needed.
Message 11 of 16
(1,733 Views)
OK, let's start over.
We have two arrays:
A=[66,77]
B=[5,0,1,1,5651,77,5797]
How should the output array look like every time it is written to the database:
First write...
Second write....
Last write ...
Message 12 of 16
(1,722 Views)
Lets say we have  two arrays:
A=[66,77,88,99]
B=[5,0,1,1,5651,14,5797]
Output should be
First write : [5,0,1,1,5651,14,66]
Second write: [5,0,1,1,5651,77,66]
Third write: [5,0,1,1,88,77,66]
Fourth write: [5,0,1,99,88,77,66]
Cameron wrote:
You're making it unnecessarily complicated (and, as altenbach says, it won't work). Just take your replacement array and use Replace Array Subset to stick it into your original array with an offset of 1 element. All done.
I just donot want to use replace array subset because i need to write it to database for each time the outer Loop runs.
Nghtcwrlr
Message 13 of 16
(1,698 Views)
Maybe this is what you need
BR
Vincent
Message 14 of 16
(1,689 Views)
Hi everyone
Using Shift Register (as suggested altenbach) is required if you want to upgrade your output table each time you execute your For Loop.
In the For Loop you also can add a SubVI which save your output table in your MySQL Database. I suggest you to use error handling as well.
Have a good day.
Certified LabVIEW Architect (CLA)
Message 15 of 16
(1,673 Views)
A=[66,77,88,99]
Output should be
See, now you are making more sense. Until now the problem description was pure gibberish and you kepy everybody guessing. 😉
What does using a certain primitive have to do with how you are using the output later. I don't understand your argument at all. You need to use the function that gives the correct desired output. Period. 😮
Message 16 of 16
(1,660 Views)
