Replace negative values from 2d array
Hi all,
I have a large dataset that I want to post-process.. My data is in the form of a 2D array of typically 1e5+ rows by 100+ collumns! I want to replace all negative values in the array with zeros.
My initial though was to use two indexed for-loops with a case structure inside looking for the >0 condition. However, this way I am practically rebuilding the array from scratch and it takes forever (had to abort after about 5 mins of calcs while I was still less than 10% done). I have attached a snapshot of my sample vi for your consideration.
Is there a more efficient and quicker way of doing that?
Thanks a lot for your time,
Harry
Message 1 of 19
(6,843 Views)
I think it is taking a long time because you are rebuilding such a large array from scratch.
I would work on the original array.  Loop through row by row, then element by element.  Use replace array subset whenever your condition is met, otherwise pass the array through unchanged.
Message 2 of 19
(6,820 Views)
This should be pretty fast
-n  * 0  /2 = 0
0   * 1 / 2 = 0
+n  *2 / 2 =+n
"Should be" isn't "Is" -Jay
Message 3 of 19
(6,815 Views)
Accepted by topic author charmand79
There are lots of ways to do this, but in your case I would just wire the 2D array to a In Range and Coerce primitive (from the comparison palette) with the range set from 0 to +Infinity.
Message 4 of 19
(6,794 Views)
I've never used the in place structure before, but I would try something like this.
Message 5 of 19
(6,790 Views)
Mads-  simple solution!  I'd be interested in benchmarking it against mine.
Wart- that would be the way to use the IPE.  Bet it would be faster if you you used the iteration terminals to replace array elements
Perhaps a combo. Try the  "Mad-Warts" approach
there should be no buffer allocation outside a scalar.  A good benchmark would give us a clue to the complier optomizerSmiley Wink
Message 6 of 19
(6,773 Views)
While Mads was busy posting I was busy benchmarking. IR&C is about 5 times faster on my machine. Someday I'll learn to post first and benchmark later. 🙂
Message 7 of 19
(6,761 Views)
Guys,
thanks a lot for all the excellent ideas.. I was about to start benchmarking and let you know but then I saw Darin's message... So I'll trust his findings and use the "in range and coerce" method.. There you go Darin. Please stick to benchmarking first and posting later !!! Smiley Wink
Harry
Message 8 of 19
(6,742 Views)
Could not resist setting up a quick benchmark myself.. It appears that mads solution is indeed the faster but, according to my benchmark, only by 5-10% when compared to Jeff's..
Just for the record, Mads IR&C replaces all negatives with zeros in a 184000 x 150 array in 310-320 ms using a rather dated PC
Thanks again to all for your time..
Message 9 of 19
(6,731 Views)
The primitives have a tendency to be more efficient than anything you can do by writing your own logic (fair enough, but it does take a bit of fun out of things Smiley Happy).
Here is a benchmark of some of the options:
I have not checked the memory usage, but I'm sure the primitive is the winner there too.
Message 10 of 19
(6,729 Views)
