Replace function!!!
Hi!
I want to replace Write to Digital Line.vi function to Daqmx write .vi in given example.
I did it but I couldn't run the VI.
if anybody knows than edit this example.
thanks
(2,863 Views)
The DAQmx equivalent is shown below. If you have additional problems, you really need to provide more information than just 'it couldn't run'. You need to provide error codes and the actual code that you've written instead of an image of something before you've made any modifications. You should also look at the shipping examples for DAQmx>digital Generation.
You'll also notice that I removed the completely unneccessary sequence structure.
Message Edited by Dennis Knutson on 01-02-2007 08:46 AM
(2,845 Views)
