Rename and Reserve functions missing in NI-MAX
Hello. I developed my project on a PC and prepared the exexutable. I want to execute the program on another PC. But on that PC if I go in NI-MAX, I can see my c-DAQ but I can't change the alias (there is not the Rename menu) and is missing also the Reserve Device function. Without these functions, I can't make my program work.
(225 Views)
How did you install DAQmx on the other system and which installer did you use?
In the LabVIEW Build Specifications for Installers for example you can choose to include "NI-DAQmx Runtime", but there is a "NI-DAQmx Runtime with Configuration Support" too. I think you just installed Runtime, but without Configuration Support.
(197 Views)
