Rename a LabVIEW project library via scripting
I am attempting to script the operation of renaming a library that is available within the LabVIEW project.  I can duplicate the lvlib file using scripting but the VI's referenced inside still are tied to the original library file.  Any suggestions?
(633 Views)
In general, you would have to write code that recurses through all owned items, saving them individually.
However if your library contains only .vi, .vim, .vit, .ctl, & .ctt files, you could create special case code that skips the recursion and only acts upon the library's owned items.
(608 Views)
Maybe this will help.
(580 Views)
