Removing the frame of a 2D picture object that loads an unflattened pixmap image (png)
Novice question here that I am regrettably posting apparently due to amnesia.
I am basically trying to view the image as best as possible without seeing the frame.I can use the positioning cursor to crop it correctly from the bottom right, but the origin at top left will always result in a gap between the top of the frame and the left side of the frame. I feel like I've worked through this before but can't remember the solution. Image attached.
(3,185 Views)
Accepted by topic author dest2ko
Are you talking about the border of the control itself? If so, you can set your paint brush to transparent foreground and background and click on the border.
Corey Rotunno
(3,176 Views)
Thank you. Between getting dressed and showering this morning, you don't want to know which I did first!
(3,153 Views)
