Removing a stubborn image from the VI front panel
I have this example VI that I need to do some modifications. There is a very stubborn image on the front panel that I can not remove (looks almost like a watermark.) I did the initial googling about locked VI`s (this one is not locked) and already spent some time trying to remove it, but I can not procced on my own any further. Any ideas how to remove this picture? Thank you.
(913 Views)
Accepted by topic author ViliusZalenas
1. Select the picture by using the mouse to draw a square and drag it into the picture. You'll know when the picture is selected because a black border will appear around the grouped items.
2. Select unlock from the drop down list
3. Select ungroup
4. select ungroup a second time, since "Sid's Classroom and TIC TAC TOE GAME" are group together.
5. Now just the "Sid's Classroom" and be selected and deleted.
(894 Views)
Thank you, it solved my problem.
(872 Views)
