Remove whitespaces from spreadsheet string
In the attached VI, I am attempting to remove all the white spaces from a generated "Spreadsheet string" block.  All the \t, \s, \r, \n.
I am using the "Search and Replace String" block but it does not seem to be working.  Can you tell me what I am doing wrong?  I have the "search" input as " '\' Codes display"
Can you assist me in removing all the white spaces?  Thanks!
(2,093 Views)
Try this (right-click on the Search and Replace String function and tell it to use a RegEx):
Jim
(2,067 Views)
Right click the node and check Regular Expression. That should do the trick. (It worked for me)
mcduff
(2,065 Views)
Right click the function and check Regular Expression
(2,056 Views)
