Remove the zoom of chart programmatically
Hello
I have some data that is being plotted in charts, and I need to save the image of that chart to add it to a report
But if I zoom in before saving, the image saved with the zoom applied, I would like that when the image is saved, it will be saved without any zoom, with the "original" graphic
Is there any way to programmatically make the chart unzoomed and placed on initial point of the graph?
(663 Views)
Option 1:
Pass all your data into 2 charts, one off-screen and one on-screen.  When it's time to save the image, save it from the offscreen one.
Option 2:
Create a property node for the chart, and manually set the X scale and Y scale Range.Maximum and Range.Minimum properties to be the min/max extents of the data displayed in the chart.
(648 Views)
Create a property node for the graph.  The property you are looking for is Palette->Active Tool.  Set that value to 5.
GCentral
(625 Views)
How can i use it for another and different graphs?
(602 Views)
To ensure the same look for all data, set the property nodes to create the same look.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(579 Views)
Wire up a reference to the Property Node and you can use the same node for any graph.
GCentral
(571 Views)
