Remove sub panel tabs when main host VI is running
This is my first time including  a sub panel in a running VI.   When I run the desired vi runs in the sub panel as pictured.
When running the sup panel includes scrolling bars on the edges.   How do I remove these?   Thank you
(1,321 Views)
Accepted by topic author montcuky
The scrollbars are part of your subVI.   Just turn them off.  I suggest you set your Graph to scale with teh panel size, so it will fit itself to your subpanel dimensions.
(1,309 Views)
Thank you so much this worked great!
(1,294 Views)
