Remove string value
My current board have data counting number as example below. The data will have number starting 1 until 10 and will loop until vi stop. I want to remove the counting number in the data string (bold character below) and remain the (0.3456) value as data output.
Current string : 1.0.3456
                         2.0.3456
                         3.0.3456
                         4.0.3456
                         5.0.3456
                         6.0.3456
                         7.0.3456
                         8.0.3456
                         9.0.3456
                         10.0.3456
Thank you.
(2,045 Views)
Accepted by topic author Anna_10
Hi Anna,
you really should implement a better string formatting when separating numeric values!
Suggestion:
(2,032 Views)
You can use a combination of "Spreadsheet String to Array" and "Match Pattern" to remove the unwanted prefix from your string:
But as said GerdW, maybe the initial formatting could be improved to prevent mixing value separators with decimal separators.
Raphaël.
(2,029 Views)
Thank you for your help. Really appreciate !
(2,017 Views)
