Remove picture control frame for a picture array
I need to create an array of 2D Pictures. Due to the large amount of elements in the array, the picture width is reduced to minimum. However there's still a substantial gap between 2 adjacent elements in the array (see the attached example), which is caused by the frame of the picture control.
I tried to set the picture frame color to transparent, but even though it's invisible, it's still there. I also tried to customize the control, but I couldn't find a way to remove the frame (for both classic and modern styles).
(BTW, for classic style control, there's a unframed option of Color Box control, but no such option for 2D Picture control. And I need pattern/pictures inside the 2D Picture control element, so simple 1-color Color Box is not sufficient.)
Could anyone help to suggest a way to remove the frame and maximize the space density in the array? Thank  you very much in advance.
PJI
(3,957 Views)
Accepted by topic author pji
Hello PJI,
you should be able to set the frame smaller than the picture area of the control.
- Right click control and choose 'Advanced' -> 'Customize ..'
- In control editor change to 'Edit Mode'
- from the menu click 'Window' -> 'show parts window'
- In the part window select the frame
- set new values for top, left , hight and width, so that the frame hides behind the picture area
Hope this helps.
UliB
(3,949 Views)
It works. Thanks!
(3,940 Views)
