Remove negative values while building a 2D array
The attached VI generates a waveform based on cursor positions and generates a results array.   However, I ONLY want the results array to contain POSITIVE value elements, I would like to discard the negative AND 0  element values.  My case structure only replaces the negative values with zero.  How do I disguard the negative values and not add them to the results array in the first place?
(4,270 Views)
Thats the basic idea..
(4,263 Views)
In second thought, it would be best to initialize the array, as you know the number of samples,
and then use the replace element function.
Better memory usage with this way.
Take a look here.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=292035&view=by_date_ascending&page=2
(4,260 Views)
I am just not understanding this one.  I tried to follow your example but......  Thanks for your help.
(4,256 Views)
How do I fix the case selector error?
(4,249 Views)
The idea is something like this.
I don't have the time to finish it, and it's a little messy.
It does not work ok.. you only check one element if it is >0... see if you can finish it
(4,236 Views)
Yes I can, Many Thanks for you time and help!
(4,234 Views)
