Remove data from array while data streaming
HI~
I am building a program which only displays and saves data larger than a certain value during data collection.
After reading previous examples from the forum, I have managed to delete those data.
However, there is an empty cell remained from the deleted datum in array.
I would like to remove that cell too, so what should I do in this situation. And could anyone explain why I did wrong?
Attached are my program and data saved in excel.
Thanks very much
John
(3,546 Views)
Just use conditional tunnel mode.
Something like this:
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,527 Views)
Use the array subset VI.
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(3,526 Views)
Hi~
I tried .aCe. 's solution and it is working. Thanks very much.
So a further question. I also observed some empty cells from the original data.
How can I remove them too?
I also tried packersFan's solution. I simply replaced the "replace array subset" with "array subset" but there was no difference. So did I used " array subset.vi" in a wrong way?
(3,502 Views)
