I have an input array (A). I have calculated the differences between
two successive elements. the result is inserted into an array.
To this "Diff" array i have calculated teh mean and standard
deviation.
Will be happy to send the code of the above.
Now.. I wish to remove the elements with values exceeding the Mean+/-
the SD, any ideas how to do that? In other words i wish to remove the
element that was the outlier of the diff array (element B)
The resuly should be the Array A without the element B..
I hope it was understood, its a bit hard to explain 🙂
Thanks!!!
