Remove Parts of a string between two sets of characters.
I am reading a series of data strings from a serial port.  RS-232.
Bellow is an example of the data coming in.
ROM TEST IS IN PROGRESS ...  PLEASE WAIT     VERSION 8
I would like to look for  and delete everything up to and including 2K then look for the next instance of  and delete to 2K.
Rinse and repeat.
Ideally the string would end up as;
Message 1 of 21
(6,255 Views)
Accepted by topic author RedneckNerd
Match Pattern is your friend...
Message 2 of 21
(6,248 Views)
You need to state your rule differently.
As written, your rule will leave nothing except "VERSION 8".
In any case, MATCH PATTERN and MATCH REGULAR EXPRESSION will do things along this line.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 3 of 21
(6,241 Views)
How did you come up with '\1B" ?
I don't see that in the original string he posted:
Steve Bird
Culverson.com
LinkedIn
Message 4 of 21
(6,229 Views)
Thanks.  I had tried something similar to this but couldn't get that initial string correct.
Message 5 of 21
(6,218 Views)
1B is the hex for the left arrow symbol  .
I kept trying to use the  instead of 1B.
Message 6 of 21
(6,216 Views)
I don't see the left arrow AT ALL, that's why I said that your written rule was wrong.
Steve Bird
Culverson.com
LinkedIn
Message 7 of 21
(6,209 Views)
It just appeared in the string when I copied the string from the browser and pasted in a string control.  Whether or not the OP is really getting that in the data, that is unknown at this point.
Message 8 of 21
(6,184 Views)
Message 9 of 21
(6,168 Views)
It definitely has a left arrow at the beginning.
Message 10 of 21
(6,164 Views)
