Remove Panel: No --- does not work...
A.vi calls sub_A.vi. When I build an A.exe application I would like stil to be able to open sub_A.vi when running the A.exe. In source file settings of the Build project I add the sub_A.vi (do I need to do this and why? imagine the amount of work for a huge application in which I wish to keep dozens of front panels available). Then in Source File settings I try to uncheck the tick in the value column of remove panel for the sub_A.vi. But when I return to the setting it is back selected. I tried different ways to build this very simple application but never I am able to open the sub_A.vi.
Also, is there an automated way to tell the application builder to keep the front panel of certain VIs? In Labview 6 and 7, changing the default VI settings would automatically make the VI able for opening in the compiled executable.
Ch. Content
(2,903 Views)
Maybe you should mention what LabVIEW version you are using (we can only guess 7.1 or higher). 🙂
How are you calling sub_A from within A?
(2,896 Views)
Sorry, Labview 8.20 (it worked ok like I said in my posting).
The subVI is wired inside the diagram of the main VI, no dynamic call.
Christophe
(2,887 Views)
