Remote panel server error on Crio 9012
Hi all
I would like to access a sub VI on the real time controller but if I open it with the remote panel tool an error comes up.
LabVIEW: Resource not found
An error occurred loading VI 'lvfpp0.vi'
LabVIEW load error code 3: Could not load front panel
If I want to open the main VI it works fine, so the address, firewall etc seems to be okay.
Best regards
Benjamin
Stay Hungry, Stay Foolish
(3,116 Views)
try unchecking everything in the vi properties under the execution menu
this worked for me earlier this week for the same error
- James
Using LV 2012 on Windows 7 64 bit
(3,094 Views)
Accepted by topic author Benjamin_
In the meantime I found also a solution which worked for me.
http://digital.ni.com/public.nsf/allkb/8F68715444302CAB86256DDD0071C140?OpenDocument
Thank you James
(3,083 Views)
