Remote debugging active but no access to block diagram
I have an executable running on a target which I want to debug. I have enabled debugging in the build properties, I have enabled debugging in the vi properties. I can connect from development machine to the exe.
But the option to switch to the block diagram simply is not there (see pic). I know I am not first one who has this problem but I could not find an answer.
Without having the possibility to see the block diagram a "debug function" is completely useless!!!
If anyone has an idea it would be greatly appreciated. Thanks
(3,925 Views)
Hi peter,
are you using an old LabVIEW version ? Which LabVIEW version are you using?
(3,907 Views)
Hi Peter,
while the online documentation of the RemoteDebugging feature always mentions that "show block diagram" switch it has been a (documented, but still annoying) bug since LV8.5 (?) that this switch isn't available...
Options:
- In your picture you show the menu of the VI. You should be able to show the block diagram by Window -> Show block diagram...
- When you create an EXE with RemoteDebugging enabled you should show that menu line to allow switching to block diagram in all critical places.
- You have bad luck when you are forced to create your own menu for the VI...
(3,904 Views)
Accepted by topic author peter
Hi peter,
This is a known issue and a Corrective Action Request (CAR 130070) has been created and reported to the R&D department. Looking through the notes in the CAR, this should be fixed in LabVIEW 2012.
Workaround:
Debug applications with the menu bar turned on
(3,900 Views)
Wow,
that would be a really good reason to upgrade to LV2012!
<angry> A bug fixed after ~5 version steps of LabVIEW... </angry>
(3,897 Views)
Thank you all for your replies.
In fact I'm using LV 2011. So I will upgrade.
(3,891 Views)
you're welcome 🙂
Have a nice day
(3,884 Views)
