Remote Panel
Hello
i am trying to access a remote panel through the web. The VI is implemented on my pc which is not the internet server in the office, but just part of the network. When i try and access the remote panel, i get an error messgae saying "invalid IP address". Does the web server computer need to have labview or a runtime engine installed for the remote panel to work when an outside client is trying to access the panel, or should my labview running pc in the network suffice and communicate the panel to the client through the web server computer in the office?
Rabei
(3,263 Views)
Hi Spring,
the pc which want to load your webpage must have the runtime engine installed. See this link for more informations: https://www.ni.com/en/support/downloads/software-products/download.labview-runtime.html.
Which IP adress did you use, the ip from the webserver or this one from your router? You need the adress from your router and you have to forward a port to your webserver.
Mike
(3,260 Views)
