Remote Panel and Internet Explorer
Hello. I have a problem with a Remote Panel and Internet Explorer. I create a measurement system in LabVIEW. It�s composed of a main front panel and a few subVIs with independent front panels opened from main Front Panel when I press appropriate button. As a local system everything works ok but I try to create a web version of this system. I decide that I can use a Remote Panel. In Web Publishing Tool I was creating a web page for each of Front Panel. I try to have the same functionality as in local system, so when in Front Panel (opened in Internet Explorer window) I press appropriate button I want to open secondary Internet Explorer window with a subVI inside. And now I�m stuck because I can�t open this secondary window in a network w
orkstation. Has anyone have an idea how can I do it?
(2,883 Views)
> create a measurement system in LabVIEW. It?s composed of a main front
I think you have two options. You can open most modal subVI panels
directly on a remote machine. The popup panels won't be in a web page,
but it will work with few changes.
A second approach would be to change the app slightly. The buttons that
launch the subVIs will turn into URL links. The links will open a web
page with a different embedded panel.
Greg McKaskle
(2,883 Views)
