Remote Control - Loading an Image
I'm using the Web Publishing Tool to try to web enable a application I've written.  I wrote the application in LV7.
Anyway the application needs to load a large blank .jpg image ( about 24000x4000 pixels which is about 624KB).  When I try to load the image I get a "The connection with the server has been broken" error.  I tried loading a smaller image and this loaded fine.  I also tried loading this in LV8 and it just seemed to freeze up.  Is there a limit on what size of image can be loaded?
Would anyone have any ideas on this as I'm new to all this remote control stuff.
Eoin
(2,623 Views)
Eoin,
I have never read from a limit with regard to data amount. I think, you should try to increase the timeout of the webserver (Tools-Options-WebServer Configuration).
Possibly that eliminates your problem...
The following document lists all limitations of remote panels:
http://digital.ni.com/public.nsf/allkb/21B9A9C913F54F918625703D004D6FD9
ThSa
(2,611 Views)
