Release called class from memory
Hello is there any ways or vis that release called classes from memory
Message 1 of 33
(1,883 Views)
Try View All VI's in Memory and Their Execution State
https://tmesystems.net/
Message 2 of 33
(1,855 Views)
This feels like a question that isn't the root of the problem.
What are you REALLY having a problem with?
  • Running out of RAM?
  • LabVIEW 32-bit exceeding its 32-bit memory space limit even though you have plenty of RAM?
  • Loading a class into memory that is broken, and it leaves all sibling classes also broken even if you aren't using the broken one?
  • Wanting to replace a class in memory with a different class on disk with the same name?
  • Something else?
If you post the actual problem you have, rather than what you think is a solution that you can't find, then other solutions may be presented.
Message 4 of 33
(1,817 Views)
even though closing vi it stays in memory.
CommandsMain.lvlibp:CommandsMain.lvclass:401_sdio_BuildCommands.vi
this is the path which stays in memory and its class from ppl
Message 5 of 33
(1,788 Views)
OK, so it's a class from a packed library.
How is it being loaded into memory?
And this is the really important question...
Why is it a problem if it stays in memory?
Message 6 of 33
(1,756 Views)
I am Facing crashing issues because of that
Message 7 of 33
(1,753 Views)
How exactly does the class just existing in memory cause crashing issues?
DETAILS!
Message 8 of 33
(1,749 Views)
I want to release the class once called because I have to update plugin during run time. While the ppl in memory I am not able to build it. And getting crashed.
Message 9 of 33
(1,743 Views)
This is my best guess to what you are doing:
  • You are running some program in the dev environment.
  • This program loads a plugin
  • You do something with the plugin which isn't working, so you want to make code updates to it
  • You make changes in dev to the plugin's source code
  • You then want to rebuild the lvlibp and reload the plugin, all the while without having to shut down the main program
  • LabVIEW won't let you because the lvlibp is in use
Is this an accurate description of what's going on?
Message 10 of 33
(1,736 Views)
