Relay timing
Hey guys,
I have  build a small program to control 8 relays on a conrad relay card.
Individual relays are controlled by sending commands with 19200 Baud without handshake signals, 8 data bits, without parity bit and with one stop bit.
The programs shown works perfectly if individual relays need to switched on/off.
Now i would like to add a timing function i.e. controlling the timing of individual relays based on user input.
Any suggestions on how to go about it would be appreciated.
(4,124 Views)
Try to refactor your code into State Machine:
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
It will help you to manage timing properly 🙂
Marcin
Think Dataflow - blog.mtapp.tech
(4,100 Views)
Use State Machine Architecture for your application and for controlling Timing you can use Elapsed Timer.
(4,097 Views)
Hi Zezendapus,
Could you please upload the vi for Labview 2012? I have the same issue and would like to give it a look but with the old version of labview that I have.
Thaks in advance.
Vanessa
(3,388 Views)
