Relay switch
DUT is monitoring. Power is given through relay. System checking the current it is taking, at that time relay is on. If current increases to a certain level relay should off. And at the same time when the program stopped relay also change its state from no to off. Can I use a conditional loop?
"Thanks with regards "
by
..........Gireesh..........
(2,660 Views)
(2,652 Views)
