Relative Build Spec Path?
So...I'm not sure how it does it, and was hesitant to install a third-party tool for something that I feel like LabVIEW should just do natively, but as suggested in one the earlier posts by @AlexElb, this did the trick:
https://www.vipm.io/package/illuminatedg_lib_ig_relative_build_paths/
No code changes required, just installed this package and voila, I magically have relative paths in build specs.
Message 21 of 23
(738 Views)
 Be sure to include a note somewhere obvious in the project specifying that that item must be installed in order for the build to work.
Message 22 of 23
(714 Views)
edit: I didn't read carefully, sorry.
Proud developer at Hampel Software Engineering where we turn '404 not found' into '200 OK'. Join us on Discord
Message 23 of 23
(687 Views)
