Regular Expression help
Just a quick quesiton --
Basically, if I want to find "cat" OR "dog" in a string, how do I write
the RegExp?
I'm using Match Pattern VI, and I'm looking for ".txt" or ".tst" in a
file name (I have the whole file name in string form). I have a
solution now, but it's not the 'correct' way. ".[tT][sSxX][tT]"
Rick
(4,597 Views)
In article <3777C27A.4B45758B@csciences.com>,
write
> the RegExp?
> Rick
I think you have to use two separate �match pattern.vi's. One for �dog'
and the other one for �cat'. Then you can use both �offset past matches'
to decide if one of the searched words were found.
Hope that helps.
Bye,
Alexander
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(4,597 Views)
